RESPONSIBILITIES:
Kforce has a client in search of a Python Developer in Beaverton, OR. Key Tasks:
Infrastructure
Integration
Test Planning
Engineering
Technical Support
- Develops action plans and processes, in coordination with management team, for integrating activities and optimizing department resources to meet major goals and objectives
- Facilitates or performs application support, problem solving, and issue resolution with internal and external resources
- Contributes and reviews recommendations for technical solutions
- Manages and/or contributes to the technical components of the RFP process
- Resolves issues and determines options for issue resolution and risk mitigation
- Defines and communicates requirements for technical environments and determines the technical scope for projects
- Provides technical estimates for project budget input to Senior/Project Manager
- Leads and owns engagements with software vendors to ensure that code and configuration requirements and deliverables are met
- Enforces architecture, governance, security, and global process standards to system changes and deployments
- Coordinates compliance issue identification and remediation
- Collaborates with other teams on integration needs/design
- Contributes to database design and creates critical-path, high-risk, advanced technical designs
- Approves proof of concept efforts and reviews results
- Enforce company and department architectural direction and ensure consistent technical approach within department
- Decide on engineering tools based on recommendations
- Allocate resources based on performance monitoring and tuning results
- Manage and enforce performance thresholds and standards
- Review and approve performance test results, recommendations, and tuning results
- Oversee and is responsible for the creation of test plans, test execution, and validation of test results
- Strong software foundation
- Python- 3.7 is what they use
- CI/CD & DevOps
- AWS Experience
- Applications Infrastructure
- Integration
- Languages: English (Speak, Read, Write)
- Typical Office: This is a typical office job, with no special physical requirements or unusual work environment
Recommended skills
ArchitectureInfrastructure
Integration
Test Planning
Engineering
Technical Support
